Wheel Arch Liner
Funkmachine
Essex
Hi - just noticed that a prior owner has cut away part of the inner wheel arch liner!! Presumably to aloan access to the horn on LH side.
Does anyone on here know if the liner part is shared with other Peugeots eg the cc or the 308/3008 as i suspect an RCZ part might be harder to find!
Any help much appreciated 👍🏻
rorymonsta
New Zealand
I dont have the part number off hand but I remember looking for one for mine as it has a bit missing. Aliexpress/alibaba had some that looked reasonable, never pulled the trigger but it might be worth a look if other options wont work
Funkmachine
Essex
Thanks Rory - that’s a good idea. Never used Ali before so might be a good test as I’m not in a hurry!
Claret63
Lancashire
They are not shared, also they are difficult to find second hand Undamaged.
I bought a new one a while ago due to mine having damage on the underside, TBH most people wouldn’t have even bothered but I like things perfect.
The price for a genuine one from Peugeot was eye watering, even the parts guy couldn’t believe the cost.
Good luck with your search.
Funkmachine
Essex
Thanks - interesting to know.
Dealer quoted me £956!!!! Where did you source yours in the end. I’m a bit like you in wanting things to be “right”.
Claret63
Lancashire
I Bit the bullet and bought through the dealer as I wanted everything genuine, mine was around £500, your quote is unbelievable!
Funkmachine
Essex
I know and that was supply only - it’s just a bit of plastic. Even via Alibaba is something like £800 plus shipping although that’s for a pair!
Claret63
Lancashire
They do come up occasionally on eBay trouble is they are usually damaged, try stellantis in Manchester 0161 8486800.
rorymonsta
New Zealand
Did you have that link to alibaba or a part number? I'm having some trouble finding it again
madcap
Netherlands
Left hand side you can find .the righthand side is nearly impossible to find.and a new one is 1100 euros
madcap
Netherlands
Had the same new one 1100 euros
Chillipip
Bin7ce smart chain
I have a decent one’s available.. both sides. Message me and I’m sure we can come to some sort of a reasonable arrangement
Funkmachine
Essex
All sorted thanks to @Chillipip ! I’m now going to have to deal with the dreaded lifting the car to get the wheel off and locking wheel nut!! Still, I’ve got a few weeks to psych myself up for it 😂😂
