An update in case this helps anyone:
Original symptom was a wet drivers footwell. After days with the hose it came down to water ingress by the filler cap. Water came in and pooled behind the wheel arch (take the boot trim off and there it is - under the rear lights)
Water pools by the wheel arch then trickles under the back of the rear bench seat. It comes out by a hole in the bodywork, under the back seat by the door sill and into the drivers footwell (under the carpet)
Solution has been a bead of silicone at the bottom of the filler cap unit - might replace at some point. Simple way to see if it’s leaking is to see whether the rain pools by the closed cap. If it doesn’t then the seal is letting the rain into the bodywork. It’s a bad design that rain doesn’t run off but pools in a small well at the bottom of the cap unit. Just to be clear, I’m referring to the seal to the painted bodywork you can see when the fuel flap is closed - nothing to do with drainage holes inside the unit.
