USB Port
AliG
Staffordshire
Hi New Member here
My USB port has stopped working. I've checked the USB stick & it plays in my partners vehicle.
Any advice greatly welcomed
TIA
AliG
Staffordshire
I did wonder about the fuse but the charger is working fine & the radio & I am unsure if it's on a separate fuse. Any advice would be appreciated.
The USB is not compatible with the cars interface?
NF7
Slovenia
Is it larger than 32GB? Mine NG4 refused to work with drives larger than 32GB even though they played normally in other cars.
AliG
Staffordshire
I have played it in my car since I purchased it. It has suddenly stopped playing?
NF7
Slovenia
Ah, I see, hmm. Have you tried any other USB stick?
AliG
Staffordshire
No but I will do. It does work in my partners transit so I dont think its the stick but it's worth a try. Thank you
joro3711
Обединеното кралство
HI all, I have had a citroen c5 x7 for 4 months and everything was fine until a few days ago. my ng4 started behaving strangely. The clock reads 1.00 and flashes for three and a half minutes. during this time the phone does not connect and you cannot launch the navigation. Only the music works. I did a factory reset having prepared a usb with the latest software. I inserted the usb stick but nothing happened (no installation started). I tried another music stick that I had before the problems started and it won't start either. I tried charging the phone and everything is normal there. Any ideas I've read a lot of forums🤔🤔🤔
