Undertray Issue
jonkirby1974
Hi everyone hope you're well.
I've a small issue with the under tray where by it keeps coming unclipped. Those 2 litttle spring loaded catches latch nicely but when I check them again they've popped free. Any ideas why? Is it not fitted properly?
Hi there I think that it's not fitted correctly as I took the tray off the wife's when I was doing an oil change its a Hdi but didn't think that there is any difference, most of the tray is fixed with bolts and the other one's have clips that then have there own grub bolts, if they are missing it will not stay in place. These can be purchased from peougeot for a couple of quid so might be a case of getting some additional one's and go from there hope this has been a little help for you an you get it sorted.
So drive safe and stay lucky
Les n Co... :beer: :dance:
jonkirby1974
A HDI I'll try and get a pic. There are 2 tabs that snap in near to the front of the car, you pull them forwards to release but they keep releasing on their own.
DRTDVL
Auckland
I've never seen an under tray on ours, is it a desiel only thing?
Yes only the diesel has a full undertray.
The petrols do not have an undertray only around edges, sump can be seen.
