Turbo Replacement
tabpops
Anybody know the torque setting for the oil feed pipe that fits on the top of the turbo please?
When I replaced one on a 207 cc GT I just made sure the banjo bolt was flush to the washer as a indicator a couple of 1/4 turns on a ratchet does the trick but not overtighten & make absolutely certain the crush washer is not out of true when seating the bolt otherwise it cause a oil leaks
chrismac
Cardiff
Had a look at Service Box and came up with this.....
The oil pipe is not listed but as you can see, anything bolted to the turbocharger is not too tight.
tabpops
Thanks for that
