Strange issue with window switch replacement - help greatly appreciated
safire25
Australia
Hey guys,
So I have a 2013 RCZ and I broke one of the window switches from the drivers side, the plastic bit just broker off, you could still open the window but was difficult so I bought a brand new replacement part (see pic) . Thinking this would be easy as there are just three main plugs that attach to this driver side window (and mirror adjustment) switch
So I removed my old one, plugged this in and all good, the driver side side opens and closes the drivers and passenger window and all mirrors BUT the passenger side window switch doesn't work anymore, it does not open up the passenger side window. I never touched this switch and it has always worked. Now this is the odd bit, when I unplug the driver side switch, the passenger switch works again. So I thought maybe it was a faulty switch so I ordered a second brand new drivers side switch and same thing
I cant find anywhere that RCZ has some child protection setting that disables the passenger side window from the passenger side switch? any help here would be deeply appreciated as the passenger cant open their window, I have to do it for them from the drivers side unless I unplug the driver switch every time
Hi there have you compared the numbers on the parts as I am sure one ends in 21 and one ends in 22 as in 2013 was the change over for the face-lift.... I had the same problem with me my wife's RCZ so the number must match. Let us know how you get on.
safire25
Australia
here is the number for both parts
96659921ZD
I couldn't find the other number ended in 22 but if this is the cause ill look harder thanks for you help
safire25
Australia
wow i cannot find anywhere 96659922ZD that is in stock and will ship to Australia but heaps of 96659921ZD grrrrrrr
Scan the car both doors have modules which control windows etc Any fault will be picked up possibly by the BSI system ?
safire25
Australia
ok will try thanks, i assumed its switch as the windows all work but only when i disconnect this part, looks like i need the other part number which is much rarer
