Squeeking Door Mirrors
tm2204
A video to fix the annoying squeaking door mirrors some people have when folding in/out the door mirrors :) 👍
ONLY AEK
greece
You could just put wd40 or something similar without doing all that
I do it in mine and I have the same result
I just have to wipe it out more than you
Great video though
tm2204
Great video though
I think as well as using WD-40 if you followed up with a grease it would be a longer term solution. This would involve opening up the mirror...
What can I say but very indeph video will help other RCZers out, if you change the indicator on the mirror would be good to spray also..
A silicon spray would also work well. I used Holts silicon spray lubricant all over my cars during lockdown. Mirrors, locks, handles, hinges. Basically if it was previously regularly moving, I gave it a dose. Doesn’t seem to leave the same residue as WD40 (which I also use under the bonnet).
