Spoiler manual operation
SilverGTi_6
Hey all, I know there are a thousand questions about the spoiler, but I couldn’t find the answer I was looking for.
My understanding is you push the spoiler button and the light comes in which means it’s in manual mode. If you push it again, it drops to the lower position, but also exits manual mode (so it is closed when the car is off).
Is there a way to get the spoiler to stay at the lower position without actually pushing it each time you enter the car (or before you exit)?
Thanks in advance.
diogosaka
Portugal
Didn't exactly understand the question but here it goes:
1) Spoiler has 3 positions, completely down, half way, full extended.
2) Spoiler operates automatically, goes up half way above 85 km/h and full extended above 150 km/h. Goes completely down below 80 km/h.
3) Manual mode only operates between completely down and full extended. One click to full extend and stay pressing (2 or 3 seconds) to completely down.
Hope this explains what you intended to get answered.
SilverGTi_6
Thanks mate. Yep, you confirmed manual mode is only fully extended. I was hoping you could leave the spoiler half way (Manually).
Chillipip
Bin7ce smart chain
You could pop the fuse out or unplug the motor and manually wind the spoiler to the desired position. Obviously you won’t be able to operate it anymore but it’s a workaround.
Mine has never worked on auto I don't bother with it anyway
FAT STICKMAN
Hopton, Suffolk
Remove the liner from inside the boot then unplug wiring from the motor, on the end of the motor shaft there is a socket for allen key wind this to raise or lower spoiler manually . Peter
