Same coil problem again
Liffiton
Sweden
So, problem with the same coil again, nr 2.
Tomorrow I will change the spark plugs to eliminate that from the start.
What do you think is the problem if that doesnt work?
Flanners
Kent
Start thinking about replacing your fuel pump if that has not been done.
Check the wiring to that coil pack it may be the plugs but you can also get a higher than normal resistance causing overheating of the coils wiring insulation
