Rubber seal on roof arch. Help!
Andy77W
Hertfordshire
Hello.
The rubber on roof arch above passenger door I sagging down. Have tried to push in and it just sags down again. (Maybe due to moisture?).
it looks awful though.
are there any solutions? Does it need a new rubber seal or a bit of silicone glue to push back into place?
Can’t find anywhere that has one of the rubber seals for sale second hand neither. Although I don’t know what the part number is as every time I look online it comes up with a door seal (which it’s not!)
Any help much appreciated
Ed wales
Newport
Hello . I used bison rubber glue and it’s held . It’s a rubber glue for tent repair and dingy and use to use it in my old job for gluing grommets together. Can get usually in a diy shop or Amazon
Andy77W
Hertfordshire
I’ll give that a go! Thank you!
The rubber seals are part of the roof arches and are fixed to the actual arches and not replaceable... Just wondering if you have had the arches wrapped if so the rubber seals could have been damaged when they cut the edges off...
Please let us know if this has been done...
