Hi all , just a quick.peice of info.on a engine issue I had when going to.pull out to overtake ,felt loss of power and like a misfire .
This felt worse accelerating from idle and got better as you got up into higher gears ,the management light came on flashing and repair needed on the nav , then settled to a solid light .
This problem is 100% a coil pack.issue which is around £20 to £30 quid and simple to replace yourself .
