Replacing Rear crossmember bushes
rorymonsta
New Zealand
Hi all, new user from New Zealand here. I may need to replace the rear crossmember bushings (5131.A4 or 5131.G4 not sure which exactly) that attach rear suspension/axle to the body. Has anybody here tried this. I should be able to but the workshop manual I have suggested to do this the whole rear axle/crossmember assembly must be removed (makes sense) but when re-attached the 'reference height' must be set/reset. The diagram/process for this seems to me (a euro car newbie) to be just pulling the car down to a certain height by attaching some brackets to the body. But then how would the car remain at this height once it has been pulled there, and why wouldn't it get there if you just reattached/bolted up the rear suspension components, as the manual doesn't indicate a means of securing it at the reference height.
Apologies if this is a super dumb question
