Removed active spoiler, "speed limiter activated" note
Greek-R
Hello,
i have replaced the Active spoiler with an "R" one, and when i go above a high speed (more than just the speeds that the spoiler typically activates - around 80Km/h and 110km/h ish) i got something* like "error in active spoiler system, speed limited activated" message does anyone know anything about this? like, how can i disable this alert/function, when does the limiter activate and what is the limiter speed limit?
*no photo since i was doing more than 100km/h...
ONLY AEK
greece
probably you have to deactivate it from the ecu
you will have to go to a dealer if you dont have peugeot's diagnostic
misterx
Maidstone
Agreed. The software has detected that the old spoiler has not activated and is telling you this. Needs to have the spoiler removed entirely from its memory!
Im sure you can just remove a cog from the spoiler mechanism so that car thinks still thinks it's been deployed and doesn't throw up any errors. :thumbup:
Greek-R
The R spoiler cannot be installed if the old one isnt removed, it just wont fit. with the mechanism and the servos in place.
probably need to talk to my mechanic if there is the error code, and if its possible to permanently disable it.
PS:
the exact error message i get above 155Km/h is :
"Adjustable wing fault
Speed restricted
see handbook"
ONLY AEK
greece
