RCZ THP200 No Cruise Control
GaryP
Essex
Hi All,
I have just had the high pressure fuel pump replaced and I have the car back (what a difference that makes in the power) but I noticed there is nothing on the screen where the cruise info was and the cruise doesn't work. Is there something that needs to be reset if the battery has been off for some time etc. can't seem to find much about it online but seems odd. Does it have its own fuse that may have blown?
Thanks for advice in advance
Gary
I would return it to whoever had it ask if they check it over it maybe a fuse issue hopefully don't forget the cruise control works in conjunction with data from the ABS system & the P0087 fuel pump fail code needs deleting from the ECU
