RCZ Diesel cooling fan
Marco71
Neath
May need to replace the fan on my 2.0 diesel, what is the code for the fan i've seen lots on Ebay with different numbers plus some fit numerous vehicles. Can someone give a number for the correct fan or car I can get one from.
Why are you wanting to change your cooling fan is there a issue with the one that is on your RCZ
Marco71
Neath
Yes, last year the temp gauge went into the red with the warning engine temp fault. I changes the temp sensor twice, housing and module by the radiator to no joy. Took the fan off and tested it and wasn't working, i replaced with a fan off a 3008 and problem solved.
