rcz 200 very slight baulking changing from 1st to second - comments plse
griffster
kettering
car in excellent condition, owned 6 mths with 60k mls FSH
is this a known symptom - are there tried and tested inexpensive ways of curing it / preventing deterioration?
PJRCZ
Swindon
Changing your gearbox oil should help.I have just replaced mine as I had a similar notchy gear change and gear changes are noticeably smoother.
Woodso
Huxley
I tried changing the gearbox oil and it didn't make that much difference in the long term.
Mine crunched a lot, changed the oil and it made a small difference. You could still feel a "reluctance" though.
Also latterly started popping out of second when changing down too. Part of the reason why it got traded in.
If you hear a clunk when changing gears let the forum know as its a generic fault & just might be related to the clutch ?
