Quad exhausts
David63
Wiltshire
Can anyone advise On who to go to get quad exhausts and remap in one go
I think your better going to a specialist for each job most exhaust fabricators wouldn’t do rolling road remapping and vice versa
I had Shane at STG performance in Wakefield build my quad system great service and highly recommended but big waiting list!
csb64
Kt246dg
I am in Surrey and looking for a quad exit to go on my 2012 HDI.Prices are high,if you don't mind what sort of money did you pay,and how did you get around right side exit ?.
csb64
Kt246dg
K,how does that look from behind,is it a obvious hack job,or ok.If you have any pictures I would be grateful.Am struggling with getting a realistic price where I am.(surrey)
There you go Stewart and what they look like is ace it makes the back end of the RCZ well balanced out.....
Bang308
Oxford
Hi, Have you tried powerflow exhaust
csb64
Kt246dg
Waiting for price,has anyone removed rear box and put a Y pipe in place to run pipes to either side? This probably would be cheaper,but I don't know what effect not having the rear box would make,MOT noise emissions
csb64
Kt246dg
Thanks just had a look,442 for steel or 343, just getting price for fitting,looks like a bracket needs to be welded on,and template to cut out exit for right hand side.
csb64
Kt246dg
Am doing the same with my Hdi,In the end I went to Celtic tuning for the map,and am more then impressed with the gains in performance but more with mpg,now getting 60+ with varied driving.I am struggling with the quad,I want to use fabrication as I can get the tips I want just right,if you buy sun sport or Ulter sport it looks like the tip are all welded together so no choice of tips.So I will continue looking to get exactly what I want it to look like.Good luck with yours.
Kash2001
Okehampton
Sorry to drag this back up, I'm looking for the quad exhaust and found an eBay cheaper one 373592151705, if bought could I just take it to a local exhaust center for fitting or will it require a specialist garage to fit.
Any thoughts on this appreciated as the back doesn't look like it's been adapted for the quad, I've got a RCZ 2.0 HDi so not sure if the rear ends differ?
Many thanks
Many thanks
You could buy it and any decent exhaust fitter will be able to install easy enough, but some exhaust fabricators will custom make you a quad rear section for similar price, don’t know where your situated but Tony Banks in Leeds offers this for around £399 fitted
Kash2001
Okehampton
Thank you for your reply, unfortunately Leeds is a bit of a way from me in the South West counties, but the info is worth knowing, maybe we could ask for one to be sent down and fitted locally if it's not too much of a trauma.
Rather support UK business than outside of.
