problem with passenger window
BetaGod
italy
hello guys, I've a problem with passenger window! if I use the passenger switch it works perfectly but, if I use the driver side switch, nothing happens.. it not move! Any ideas?
If I open or close the driver's window there is no problem!
thanks
It could be the switch on the drivers door if you know anyone nearby you ask them if you can try there switch but there's two different switches they look the same but they have different numbers...... This is your first choice and if you find it to be the switch then it's a cheaper fix. If you try this and still not working than it's an expensive fix as it is the door regulator that is faulty..
Hope this helps you out..
BetaGod
italy
Unfortunately there is not any RCZ in my city :( there is something i can test with a multimeter or?
Petrus Doyle
Essex UK
thanks
I had this trouble with my last Peugeot. It was a new driver side windows switch at fault, found one for cheap on ebay
BetaGod
italy
hello, i changed the switch but the problem persists! any other suggest?
Firmware issue as the Auxiliaries are controlled from the BSI module also may be wiring open circuit could affect the systems operation
When you operate the switch for the mirrors do they work as normal if so then the switch is fine and it's down to the circuit board inside the regulator a good auto electrician can check it out as could be a condenser or resistor that is faulty or on its way out...
Hope this helps you out....
BetaGod
italy
there is any way to "reset" or fix the firmware?
but if there is a condeser or resistor or something broken in the regulator is normal i can open the mirror without any problem with the switch of passenger side?
Rest the BSI the procedure is listed on various post's on the forum
I did try reset procedures and no joy so If the driver side door switch will not close the window but the switch does work to operate the passenger door window then I am %100 sure it is the regulator as mine did the same and I did buy new battery, new switch, and then window motor with regulator. Changed the regular and hay presto all working fine.....
BetaGod
italy
can you link me a post? i don't know how to search!
is possibile to buy only the regulator?
I don't know to be honest I got a second hand motor with the regulator in place.... As for setting you window it's in the handbook I think it's on page 22 but could be wrong look in the index section of the hand book
john207
Greece
γεια σας παιδια.. ξερουμε την λυση του προβλήματος? γιατι εχω το ιδιο προβλημα.
