PCV valve going south?
Looks like my PCV valve is failing or about to fail had some blue smoke in traffic jam & I suspect their is a vacuum in the top half as I couldn't get the oil filler cap off without a pair of pliers !👀🤔🙄
Cycle Guy
Kent
Sorry to hear that Pedro but I'm sure you will find it a breeze to change after all you are the sites go to tech guy. Is your car a petrol or Hdi ?
Petrol so hopefully its more or less a straightforward job I will have the valve seals out while I have the rocker cover off as they are probably on the way out as well
NF7
Slovenia
Petrol does not have PCV valve but a PCV membrane on the top of the rocket cover. You can replace it yourself on the 200THP, but I do not think its possible on the 156THP as its completely inside the rocker cover.
Yep membrane-pressure cap- flap- valve BMW speciality oil mist stopper etc whatever takes year fancy its still a pain in the butt to fiddle with as I'm currently fixing 3 cars at present so I'm leaving the beast till last 👀🙄
  • Like
Reactions: NF7
