P1062 + P1030 fault codes ' variable valve shaft lift pinion' - advice please - engine running fine, occasional yellow engine light last few days
Griff4.3
kettering
2011 200gt : P1062 + P1030 fault codes ' variable valve shaft lift pinion' - advice please - engine running fine, occasional yellow engine light last few days, ticking from engine all temps for few mths
Main dealer wants £280 to inspect but is suggesting car be written off as will need new head! 65k and always run fine, main dealer serviced (by them)
Sister's main car and needed for work commute URGENT HELP please!
Griff4.3
kettering
dont u just love modern engine design..... fit everything with a crate Chevy small block and sit back for a few laps of the globe...?!
Have you ever had the Chain tensioner changed ?
  • Like
Reactions: lfe
The tensioner may be one of the issues as there a known pain on all these engines & its a chain rattler when their worn
Griff4.3
kettering
Can chain health and tensioner be checked with just camcover off - if not what else / cost required to check?
thanks
