Oil advise
Ccobbo992
Essex
I saw a post on here regarding oil but can’t find it again.
I need a top up and I believe the recommended is 0w30 i have a 2.0 hdi with the mileage on it Iv got 5w30 fully sym never run fully sym before just seeing people’s thoughts on it.
Nemi
Lithuania
I use Total Quartz Ineo ECS 5W30 on my petrol RCZ. I used to buy 0W30 but my RCZ burns a lot of oil so thicker one helps a bit :rolleyes:
If your car is in the upper mileage range use the 5.30 Quartz Ineo Low saps code 3 if available it has the best protection for the timing chain & valve train running gear in HPT Petrol's & Diesels 0.30 breaks down too quickly in these Engines
RCZ1.6
Byfield
Hi, I have a 61 plate RCZ 1.6 THP and the oil light has come on, I have read the manual and it states that for vehicles that have no particle emission filter A3/B4 is required and with particle emission filter C2 or C3 is required... question is.. how do I tell if my vehicle has an emission particle filter fitted or not?
many thanks
many thanks
You need the C3 0w-30 or 5W-30
