Need help "engine mounts"
santi
madrid, spain
Hello people, first of all, I hope all of you stay safe.
Let's star,I going for a stage 4 in my Rcz,so this is the " route-map"
Stage 3 ( engine mounts)
  • Upgrade pistons and connecting rods. (here is my problem, the engine code for my car is EP6CDT and all the pistons and rods I found are for EP6DT or EP6DTS ) are all the same pistons for the engine?
Stage 4 (Turbo)
  • Upgrade turbo (Recomendation, Hybrid using a JCW or 207 RC internals? or Mambatek, Frankenturbo etc)
I need your opinion and if you know any good seller that placer orders to Spain please tell me.
ONLY AEK
greece
Why don't you buy an r's turbo?
It's bigger than jcw or 207
santi
madrid, spain
Because the "R" turbo is not plug and play, and here in Spain we have "ITV" similar to Uk "MOT" but is very dificult pass the test if you modded the car, for example if I install a big brake kit from brembo or similar or change the coilovers lowering the car we don't pass the ITV unless you get an enginiering that make a project for the car.
ONLY AEK
greece
Then you should take a jcw
I have a hybrid turbo with 207 rc's shell and jcw's internals
With upgraded pistons and rods you should be able to output near 300 hp
