media screen issue
CraigB
Gloucestershire
Hi all,
I have a GT RCZ ( 2013 ) and the media screen rises as normal, lion appears and then the screen goes blank. The parking sensors do not work and also odometer is now in Kilometers rather than miles also have no radio or cd function, anyone got any ideas or had the same problem? Many thanks
CraigB
Hi all,
CraigB
Check the power of battery ?
CraigB
Gloucestershire
Hello, it’s had a new battery fitted and they tried a software update but nothing, garage seems to have no idea?!
Did they reset the BSI ? There is what is termed as a "Load Management system " together with" Economy mode" built into the Zs which is a power saver when its enabled due to low battery power some of the Ancillary functions don't operate to save the power until full power is restored if you had a new battery then try a reset if that fails then it could be a circuit fault
If you have a code reader check the ECU any fault codes
It is in one of the links I posted, but here’s the BSI reset procedure if you want to give that a go...
If you want to try a BSI reset :-
equipment is switched off.
ignition.
15 seconds.
not open doors.)
BSI related items.
Don’t know if it will help but I suppose it’s worth a try if everything else has failed.
Goatz
London
Perhap a hard drive issue. You could resolve it by replacing with a compact flash and doing a firmware update. Would cost £25 and Is 10 mins work. It’s not a bad idea anyway as it would speed up boot time, and these navidrive units are riddled with Hd issues.
Bunkboy
Spain
Hi all,
CraigB
I have exactly the same problem as this. Is it a new display or is there a fix. have tried battery reset ,but still no joy
