Low Tyre Pressure. Warning light
Potnoodle
West Yorks
Hi,
Does anybody know why the 'Low Tyre Pressure' warning light will not go off. I've pumped the tyres up to required pressure (only one slightly under).
Still got light and a bong when switching on. Warning now states 'more than one tyre under pressure'.
Any advise would be appreciated.
It depends on what the tpms are set at... Also if you take the car for a drive it will reset itself... If this fails then you may need new sensors fitting as the battery is is built in and may be on its way out.. Hope this helps you out..
Potnoodle
West Yorks
Thought it might reset after drive but no joy. How do I find out what tpms settings are and where are the sensors located?
Hope you can help.
Cheers.
Potnoodle
West Yorks
Thanks for the advice. I'll let my mechanic mate plug in and see what it reveals.
