VirtuaIceMan
1. Is the car meant to have front parking sensors, as well as rear? Not had any beeps from the front when getting close to things.
2. The shocks seem to be knocking a bit over any kind of road imperfection. I've seen people mentioning this as a known thing with RCZs, if it's never been fixed yet, any tips what to ask Peugeot to do/check?
3. Front brakes on hot days squeals loudly when braking gently. I had this on a Celica GT 2006 before, am hoping it's not a warped brake disc, as I suspect they're a bit pricey?
4. I noticed that when turning wheel from lock-to-lock there's a slight "chirp" sound as you spin through the centre position. I'm not sure if it's the steering column or elsewhere in the steering, any ideas?
I'm also finding it hard to get comfortable, with pain in right-shoulder, despite trying chair high, low, in-or-out! I seem to have to drop steering column so low the wheel obscures the temp/fuel gauges to help a bit.
Finally, is the clutch meant to feel rather heavy and a little notchy? You only need to seem to depress it about halfway to change gears, or should it be pressed to the floor every time? I'm becoming a king of nearly stalling and/or bouncy 1st-to-2nd changes!
Oh and beware of trying to fit ISOfix seats in the rear; I caused a little damage to the seat lining trying to get it unlocked again, it's rather tight!
