Peugeot in their infinite wisdom have made the side repeaters a closed unit. Meaning, that if a bulb goes, you have to replace the whole thing instead of just the bulb.
Fortunately, this is easy to do yourself.
I replaced mine with black ones, but its the same for a direct replacement.
Step one:
Unclip the side repeater.
It has a metal clip at the top and bottom of the unit. The easiest way I have found is to pry it out from the bottom using a small flt head screwdriver and once the bottom is free, you can pull it out with your hands.
Step two:
Unplug it.
Its just an easy black plug. Remove this and the unit is free.
Step three:
Plug in the new unit and then push back into place.
All done.
Step one:
Step two:
Unplug it.
Step three:
All done.
jactac said:Definitely worth popping the repeater of every few months and giving the insides a spray of WD40, it's something I will be doing.
A quick & simple bit of maintainance :thumbup:
