thornebt
- Joined
- Feb 23, 2014
- Messages
- 234
- Reaction score
- 10
- Points
- 18
I had these warnings come up a couple of months ago after getting a bit bogged down in a muddy field and subsequently cleaning mud off the wheels with a jet washer. The fault disappeared though. I've now got the same ESP & ABS warnings coming up and I was just driving slowly on wet roads. I've got a local auto electrician I can try but before I do that is there anything I can check? Any sensors I can replace or parts I can inspect / clean?
I've got a OBDII code reader but it doesn't diagnose any faults as I think you need a specialised code reader for brake faults.
I could leave the fault for a week but I don't know if it will always flash up or if it will clear when the fault disappears, maybe something just needs to dry out?
Cheers. Bruce.
Cheers. Bruce.
