Help needed - brakes won’t bleed…..😢
Logikmaster
Edinburgh
Hi all, hoping someone can advise as it’s annoying the **** out of me.
So needed rear brakes pads & discs, so whipped off the old stuff and the first caliper went back fine, the second one though wouldn’t budge back so I removed it and left the pipe in a jar to catch the wee bit of fluid I anticipated. Stripped the caliper and rebuilt it all fine wood the piston back lovely then went and refitted it to the car and connected everything up and refilled the master cylinder ready to bleed…… therein lies the issue as I have bled many a motor over the many years and started on the rear left expecting plenty of air and movement etc but not a great deal.
Symptoms are now that you can pump the pedal up and it then goes down whilst you have your foot pressed on it and when I start the car it says ‘STOP’ and bleeps with a brake sign on the centre display on the dash. Scanned for codes - none, read online there is a ‘second’ bleed that can only be done using the diag tool at specialists or dealers?
Why would it not pump up when all that happened is the brake fluid drained through? Is there a way to bleed it at the master cylinder?
any help would be much appreciated as I can’t drive it to a dealer or specialist as it’s got no brakes now…….🤷‍♂️
thanks
Looks like you got a lot of air in the system causing a vacuum may need a full bleed off 4 wheels depending on the sequence of which wheel first
Logikmaster
Edinburgh
On this video looks like it is a normal bleeding procedure.
Maybe try to use a vacuum brake bleeder
Aye I think you are right guys as it seems there is not enough pressure in the pedal action with all the air in the system to push to fluid through, so I’ve ordered a Sealey pressurised brake bleeder so will give that a go when it turns up end of the week and let you know how it turns out 👍
simonf7
West Sussex
Hi there, I understand that this was over 3 years ago now, but did this fix the issue for you? Yesterday while I was driving and the same error came up on my dash. After having a look around I discovered that brake fluid was leaking quite a lot out of the rear left bleed nipple. After tightening it no longer leaks, however when I filled up the brake fluid reservoir, it still comes up with the error message.
This makes me think that there is now air in the system. Any suggestions on bleeding?
Thanks.
