Hello and help!
Tartan_special
West Lothian
Just bought a 156 GT and was looking for some advice.
How do you remove the mirror indicators as mine have misted and ive bought some replacements.
Also do i need to remove the airbox to get to the map sensor?
Bosch Map sensor is in the inter cooler return pipe (left side of engine) you can't miss it its at the back near the air filter & is accessible from the top its held in by a 8 ml screw (bolt in Type) so you need a socket just unplug it take screw out but be wary as its a little fiddly I have not taken my mirrors apart yet but I have been informed there is a vid on Youtube showing a guy taking the glass out
You will need a sturdy plastic trim removal tool to remove the mirror indicators, what I did was offer up the new indicator to get an idea of where the clip is located, push the trim removal tool underneath the indicator lens you have to put more pressure on the mirror than you think is right but eventually the tool will slip under the lens and it pops out, You will probably find the alloy mirror bracket is all furred up with corrosion I sprayed loads of chain grease over it .
