Heater coming on by itself
Woodso
Huxley
In the last couple of days the heating has started coming on by itself. I start up with the heating off and within 20 secs it comes on by itself, so I switch it off but within seconds it comes on by itself again. Tried multiple times to turn it off but to no avail.
Any ideas as to why?
Woodso
Huxley
Again, Air con is not something I normally use. I did notice that if I dial it anti-clockwise past the "Off" position it comes back on again. Previously if I dialed past the "Off" position nothing happened, it stayed off.
I guess I will just have to keep it on Low during the warm weather.
The Air con sensor/gas pressure may be at fault its poss the ECU BSI has spiked a temp fault somewhere you may need to have it scanned
