Fuel smell
Marmite
Has any one got any ideas why my r smells of fuel inside the cabin an the engine bay , it’s been serviced an had a new low pressure pump in the tank an a high pressure pump replaced I cannot find any fuel leaks .
Have you checked for leaks while someone revs the engine? If you’ve had the hp fuel pump replaced it may be a small leak that only occurs under pressure🤔
Marmite
It dose it while ticking over the only way to stop the fumes to put the air con on recycle but I want to get to the problem an sort it if I can
Marmite
Up date on my last post it was was the exhaust gasket between the turbo an cat , the fuel smell has gone an the Mystery of the pink dust over my r , s engine is solved thanks to this forum
Great news, Result !!!! & thanks for posting the solution it might help others on here in the future.👍
