Look on YouTube... As it has many videos. I have seen them and very easy job.. I would disconnect the battery before you can started due to the air bag..
On the back of the steering wheel there are two indentations this is where you put a thin flat head screw driver in this pushes against a wire clip that holds in the air bag once you have done that you disconnect the bags connection and there is only one bolt in the middle of the cars wheel removing this and the steering wheel comes up and off.. Refit in reverse order do not forget it put your steering wheel on straight.... Hope this helps you out...
Merry Christmas
Drive safe and stay lucky
