Driver’s door glass
TL17
Hi, I’m new on here, hello to all. I’m stuck with an issue in that my driver’s window is stuck in the fully down position. I can hear the motor clicking if I hold the down switch but nil when I try to raise. I’m trying to remove the glass to get access to the motor (ie panel is off and I have access) but with glass down that in itself is an issue. Ideas?
Have you tried to manually lift the glass while holding the button to raise the window?
TL17
Yes, tried that, no success BUT have managed to remove glass and regulator, motor lowers but doesn’t raise, regulator free as moved it manually, stripped switch down and seems clean, contacts good. It has had the airbag go on that side - all three - so I wonder if there’s some interlock tripped that needs a reset?
I’m not sure if this is part of the BSI control, but you could try a BSI reset, at least it can’t do any harm. If you want to try a BSI reset :-
equipment is switched off.
ignition.
15 seconds.
not open doors.)
BSI related items.
TL17
Hi, old thread but current subject sadly.
Drivers window AND mirror not working. There has been a bump on that side of the car but glass and regulator free. Have changed switch with working spare, switch lights so power present, but nil mirror movement or glass moment despite that controller does work the passenger glass and mirror. Any ideas where to start looking? Anything that would affect only the drivers side of everything but not passenger? BSI reset tried but window stuck in closed so not sure it worked correctly.
