driver side window
rob1robno1
hi guys..i just replaced the driver side electric window motor and everything works ok with the door open..but the minute I close the door the window opens half way..if I sit in the car and hold the button up the window will go up to the top but then go straight down to half way again..window works fine with the door open...car getting on my nerves now..any ideas guys.. ( I also disconnected the battery for half hour but the minute I connect it back up the window opens again to half way)
Strange one that :eusa-think: possibly needs a reset I’m sure there is a step by step guide to BSI reset on the forum do a search for it and that will hopefully solve it :eusa-think:
Try holding the window switch up till you hear a small click, then down till you hear the click.
Usually hold it for a few seconds but you should hear a quiet click.
If that doesn’t work, the procedure for a BSI reset is :-
equipment is switched off.
ignition.
15 seconds.
not open doors.)
BSI related items.
If either of the above solutions work, don’t forget to let us know so it might help others with your problem in the future.
I have had the same problem with the wife's RCZ and it turns out it was down to the window regulator changed it and all OK after that
MJZ
France
Hi V…can you tell me what the window regulator looks like, where can I get one or see one and how easy is it to change it…much appreciate some info…many thanks….
