Double din issues.
Hi there, i've had a Sony double din unit installed today by a very reputable specialist locally, they installef a similiar system in my previous vehicle with no issues,, only problem on my Z is that i've no sound now from my parking sensors,, display is still fine, proximity bars still show but no beeps for how close i am. They did phone whilst installing to say they had this problem but no matter what they couldn't rectify. Anybody had this issue or know what the fix may be??
Cheers in advance.
Aaaargh,, another bloody adaptor to buy!!! Cheers for that,, i'll order and they can pull the whole thing out to refit :) Good to know i can retain though,, thanks for the info.
Nope. Few things to take into consideration,
When installed an aftermarket stereo on my DS3, similar system to the RCZ, few problems:
If you'll be using the head unit to power the speakers, just an adaptor, as mentioned above. The adaptor will hold most of the functions of the stalk. No problem.
If you'll be using an amplifier, as I assume they'll be connecting using the RCA, the problem is that the RCA just will send the audion, not the bips to the speaker, and will be unable to lower the volume when the parking sensor is active.
Simply, when using and adaptor, without an amplifier in the system, the new head unit will send the audio to the same "route" as the original head unit, so the system still able to control what goes to the speakers.
When using an amplifier, and it's RCA, the new connection will be independent, as the speakers will play what the amplifier sends to them, and the system won't have any control over it, as even using the adaptor mentioned before, the audio won't be using the original "route".
Another option would be using a low-hi converter, using the adaptor mentioned, and after the adaptor, when the cables return to the "route" to the speakers, you route them to the low-hi converter, them send the signal to the amplifier, and from the amplifier back to the speakers.
The easiest plan is just using the adaptor and without further mods, the new head unit will power the speakers.
Including an amplifier, complicates everything, but if it's your plan, I can drop few tips to avoid my mistakes.
Just as a note, most standard speakers will be 2ohm. Using an aftermarket head unit, even with a more powerfull head unit, the standard speakers may sound weaker than before. Worth checking if the RCZ uses 2ohm or 4ohm.
For the RCZ, upgrading speakers was quite easy, just the 6x9 which I canibalized the mounting and used Alpine front and back. No amplifier for my previous RCZ, later using an amplifier for my previous DS3. During the installation of the speakers, some soundproofing and voila.
If unavailable you can order similar adaptor for Citroen and it will be compatible. For my RCZ used one for Citroen, as the authorized dealer from a local shop confirmed, they're identical. Wou'll need an Sony lead as well.
And to access the car menu, you'll be using the stalk.
