Valex
- Joined
- Jan 29, 2021
- Messages
- 165
- Reaction score
- 118
- Points
- 43
- Location
- The Netherlands but Italian :)
Reading around the issue with the stretching distribution chain and the bad engineered tensioner I'm looking to collect more info are possible before let a mechanic do the job.
When I turn on my car (156HP 110.000 km) the rattle noise is not so loud but the first kilometers, if I go above the 2000 RPM the noise is really bad. When the oil heat up it is fine and no rattle noise.
No information if the distribution chain was previously replaced.
About the tensioner, I found out that the Mini (BMW) one should be better and searching for the part number I found this text on a website (just copy and paste):
MINI Cooper Chain Tensioner ONLY. Part #11-31-7-607-551 or #11-31-4-609-482 are interchangeable. We highly recommend installing the . This is the newest and up to date tensioner. This tensioner will will work on all the Gen 2 cars with an N12 or N16 Cooper engine, or the N14 & N18 Cooper S engine. This tensioner is 8mm, which is longer than the older standard size 78mm tensioner. This part is also bilaterally exchangeable with part number 11-31-4-609-482 and we stock and have both part numbers because MINI will send us both depending on what they have in stock no matter which part number we order. Both tensioners are the same size and length with the same spring. We can't explain why MINI has two part numbers, but they do.
MINI Timing Chain Tensioner. If you start up your car in the morning and you hear a rattling at start up or when it's cold out, then you are having a problem. Once it starts to rattle, it can jump teeth and cause the car to run poorly. It can even get so bad as to be off several teeth; and get to the point you cannot drive it without any check engine lights. We have seen the tensioners come loose from the block, the tensioners completely fail, the chain stretch (badly), as well as the car skips teeth, causing the timing to be off! If you don't want to do the whole kit you can try just adding this longer tensioner. But we still highly recommend installing the full kit.
As an added benefit, we are cryogenically treating the tensioner. The cryogenic “heat treating” process is where the material is cooled to approximately −185°C (−301°F) with the use of liquid nitrogen. This increases the amount of martensite in the steel's crystal structure, increasing its strength and hardness. This in turn will not allow the chain to stretch or the tensioner to fail as quickly, if ever. This keeps your motor in time better as well as run more quietly and last longer with the proper maintenance. Note: Customer must keep oil in the car.
Note: Torque to 48 ft lbs. (65Nm).
It is just a copy and paste so, where is write "We highly recommend installing the .” the part number is missed but reading the rest of the text looks the Part #11-31-7-607-551 is the recommended one.
Very interesting and I hope this information can help the forum community.
Abut the cryogenically treating, probably it is good but it is not the subject of this thread, it is just part of the copy and paste .
About the distribution chain (kit), is there a recommended one? My knowledge stop to the point that the original Peugeot one was replaced with a stronger one but not everybody think that this is the true , also the better one stretch !
Please share your knowledge !
