Hi Guys,
Im so concerned about this that I thought I would post this as a new topic.
THIS IS SCARY!!!
Ok so I spoke too soon. I had a puncture and I thought it was fixed with no damage to the lifting point but alas no. The puncture was not fixed, turned out to be a double puncture with the two holes too close to plug separately so a new tyre is required. Anyway after fitting the new tyre I looked at the jack point and this was what I found to my horror!! This was done at my local garage that I have used for years. They used a conventional trolley jack to lift the car.
The jack point on the front drivers side has bent out and ripped itself away from the bottom of the car and is effectively lying flat. The plastic skirt around the sill is now being pinched by this bent jack point and does not looked damaged, hope it will spring back into place when the lug is straightened.
It is clear that this is not strong enough to take the weight of the car, there is no substance to this and it does not appear to be attached to anything of any strength. It is going into the garage for a good look tomorrow but it will need straightened, welded and then re-sealed. I would be very weary of jacking the car up again with this point. Indeed if I need to get the wheel off for any reason then I will be going back the the dealer and not my local garage. Fortunately as i know the garage they are going to repair the damage, they have never seen anything like this before while simply changing a tyre.
I can't emphasise this enough to everyone. Don't think about jacking up the car at anywhere else but the dealer so if it all goes wrong they are to blame. These jack point are definitely not fit for purpose and I will be complaining to Peugeot about this. I am not a happy RCZ owner at the moment Has anyone else experienced the same this? I know a few (Ron) have on this forum.
Any comments welcome.
Regards
John
THIS IS SCARY!!!
Regards
John
