CYLINDER 3
disco
swansea
Hi All
Just removed spark plugs and found oil on top of cylinder 3 156THP, Any ideas on reason and possible to cost to fix please
I would try a compression as test on all cylinders oil in the chamber could mean ring or gasket problems other causes can point to valve leakage if its blowing blue smoke although a turbo issue would also cause that to happen worst case scenario has in the past been known as a hairline fracture/gasket blowing in the head but its a case of elimination
