Coolant sensor
bulldog b
west yorkshire england
Hi guys, the temp control keeps popping up saying, top up water violent, however the water was fine so I put in a new sensor, however it is still doing same, any ideas plz??
Was it a Bosch replacement sensor ?
If its not Bosch its useless Many have tried the aftermarket ones myself included & they are S***e my ebay special lasted 4 days when replaced with the Bosch the light went straight out so try disconnecting plug then start the car switch off & reconnect the plug then restart if it persists you need to wipe off the code in the ECU with a scanner if that fails to cure it it may be another issue but you need the codes cleared first
bulldog b
thanks for that i will try it
th3g3rmb0y
Ulleskelf
Is it easy enough to replace the coolant sensor yourself? This is the one I have.
Macro Tsai
Taiwan
在網路上看別人換過,我自己也試了一次,把它切開,重新焊接感測棒跟電路板連接的地方,就修好了
