Coolant hoses
Lanciaman
Scotland
Hi all. Appreciate there's a lot of info on these but it's a quick one.
I don't have any leaks at the moment but is installing the 2 coolant hoses from mtc motorsport cover the what seems common hose leaks, or is there more to it than that?
Just thinking preventative maintenance.
Guidance welcomed! Thanks
The usual culprits on these engines are the Thermostat tanks & water pumps also bypass pipe from the water pump which runs along the rear of the cylinder head the "O" ring can start weeping out of the coupling & is a swine to get at so hopefully you never have that issue
No putting different hoses or upgrades won't mean it will leak
