Codes and problem with acceleration (jerking)
Blantche
Poland
Hello,
At the start, sorry for my English, but it's not my native language.
I have problem with acceleration with my Peugeot RCZ THP 1.6 200. Car work properly when I drive normally, but when I accelerate dynamic (often when I accelerate up the hill) the engine jerks and get error then engine loses revs and I need to stop the car, wait about 10 minutes then I can drive again.
After error, second coil stop working (before error show ups works properly)
I changed all the filters, oil for 0W-30, smart plugs, water pump sprocket tensioner.
My mechanic said that the turbocharger needs to be replaced because it is slightly leaking.
Codes:
P1336/P1338 - I hope changing the second coil will fix this problem (i ordered and waiting for arrival)
P0948 - I read the forum before and some people said that can be a problem with oil pressure sensor or oil pump solenoid valve. Which one, do you think?
P0948 relates to Hydraulic pump relay circuit too high
P1336/1338 cam & crank sensor bank 1- misfire or multiple misfires coil or plug issues might be the cause loss of power
Blantche
Poland
I read the codes, but don't know what the P0948 means. What check first, oil pressure sensor or oil pump solenoid valve?
Search for the posts from Valex he had similar issues I think he changed the solenoid valve if I remember rightly but P0948 could mean the solenoid is going to fail?
rcz200it
Genoa, italy
Hello all just found out I need to replace my accelerator sensor that was causing esp/asr light to come on! They have no available in Madrid so from France it comes for €500 fitting included!
rcz200it
Genoa, italy
Basically it triggers the red asr/esp light on because it’s a fail safe system that you can still use the car but the double sensors get different values hence the light coming on!
