Clock not holding memory
Sijamor
Laguna Quays
Hi folks, recently had to have the ECU, BSI, Ignition barrel, and multifunction control unit to an electronics expert for bench testing, repairs and programming. Due to not being able to start the car. Everything works well EXCEPT the clock doesn't hold its memory between starts. Any ideas?
Have you had any luck sorting this issue out as I know that someone else is having the same issue each time he gets back into the car the clock goes back to 12 o'clock
JvdBosch
Eindhoven
Maybe connect a laptop to the car and see if there is something you need to configure for the clock to work?
