Car won't start
robbieh
Hi guys. Need help again!
Yesterday went out in the car and fine no problem at all. Parked up then went to go out later and the car turns over but won't fire. Also now I've noticed I can't hear the fuel pump making the prime sound when you 1st put the key in the ignition? I've checked the fuse but am now stuck as to what to check next? Maybe the pump itself but not sure where it's located.? Thanks in advance
frankvdb
Eindhoven (The Netherlands)
Did you check the battery?
robbieh
Yea. Car turns over great just wont fire? Maybe pump relay? I dont know
Electrics - Fuel - Ignition,
go through the list with each specific area,
ie; electrics - battery, starter motor, fuel pump ( in more than one topic ), fuel - is it getting through ( again pump ) filter - yes it has one and it is in the tank !!! plugs, ignition, coil packs ......
you get the message....
Good luck.
Cheers M... :beer:
robbieh
Thanks guys. Will be looking today at the car. Start with the relay the check power at the pump. I think it's on the top of the engine? See if it's getting power. But after that it'll have to be a mobile mechanic I think?
robbieh
does anyone have a picture of the fuel pump or the position of it?
thanks
robbieh
Meant to say I've had no codes at all come up?
robbieh
Thanks for the video. Not the same problem that I have but at least I now know where the pump is! I've got someone coming over today to do a full diagnostic. Way cheaper than peugeot. Friend of a friend. Only £20. He has got all the diagnostic software so hopefully I'll find out later today and let you know the results
RCZ Downunder
Melbourne
May I ask did you eventually find out what was causing the No start issue??
I’ve currently got the exact same issue with a 2015 200 tph . No pump noise when key is turned to on
DemetriZ
Limassol, Cyprus
I had a similar non-starting issue the very next day after buying the car... which is probably the reason the previous owner wanted to sell it so cheap... judging by the recent mechanic's receipts I found in the car.
The previous owner had changed the high-pressure fuel pump, but the pipe that was going to the pump was cracked, so fuel was leaking and the engine would not ignite.
Waiting for the new pipe, and hopefully I bagged myself a bargain.
On mine, on cold start, the pump is only heard when the key is inserted, not when it is turned.
But even if the pump is heard, the pressure before the high pressure pump does not increase to approx. 5 bar until the key is turned.
This pressure can be checked in two ways:
- With a suitable pressure gauge in a valve on the side of the timing chain, the valve looks like one to inflate a tire
- Through the OBDII connector, controlling the fuel rail pressure, when the key is turned it must go up to around 5 bar and then up to around 50 bar or more when the engine runs.
RCZ Downunder
Melbourne
turns out it is the primary fuel pump located on the top of the fuel tank which must be removed for access, doing this job today and not looking forward to it
