Cxngomez
Hi, I have a problem where my Peugeot RCZ resets the digital clock as well as the analog one as well as setting the alarm off and ends up kicking the keyfob off so I cannot use it to disarm the alarm I have to end up unlocking the doors manually and putting the key into the ignition and into acc to switch the alarm off and then my keyfob work again for the next 3 minutes
I’ve changed the battery on the keyfob as well as do the bsi rest and it still doesn’t work sometimes it last a bit longer than 3 mins but still sets the alarm off
I’ve tried locking the door manually so that the alarm isn’t armed but my keyfob still gets kicked after a certain amount of time and can’t be used for central locking until I put it into the ignition and turn it to acc
please help with any ideas as to what could be causing this?
