Blackcapbob
Afternoon All, My wife's RCZ 200 has a blow diaphragm in the servo, hissing sound in the passenger footwell and small amount of fluid oh and rock hard brake pedal !!. I know servos dont usually go but this one has and at the moment its been a pain.
I have a replacement servo and the Peugeot tool 0818Z to uncouple the servo rod from the brake pedal bar (Toe board assembly), and there the problem begins.
The manual states ' Pull gently on the brake pedal and uncouple the rod of the brake servo from the brake pedal using tool 0818Z ' and a crap photo of where the tool goes.
I have taken the glove box out to give more space, I have tried to locate the tool with the servo bolted up and later unbolted and the mounting slackened to give more space but I can not fathom out where the tool goes, it is a plastic tool and will break under any force I suspect, there is a white clip in a metal container welded to the bar of the brake pedal and that is holding the servo rod in place.
Is there anyone that has replaced the servo on their car, and how did they go about it other than give it to Peugeot to sort, when I spoke to my local Peugeot garage they said servos don't normally go, we don't do any work on RCZ's so don't bring it here !!!.
Any help would be appreciated, Cheers Bob.
