Bad musty small in car when starting
johnw230873
New Zealand
When I start my car up I seem to have a musty small in the car for the first minute coming from the air vents, start the car with the fan off and it isn't very bad. Thinking about it I haven't seen any water come out of the AC pipe for a while and I'm thinking it could be the AC drain pipe which could be blocked??
I've had it over a pit and I couldn't see the drain pipe so suspecting it could be behind the metal guide above the exhaust which I can't get too without taking the exhaust off. I also haven't had much luck getting to it from the inside of the car.
It was suggested to me that maybe there are some other drains blocked so I've looked under the washers and confirmed that the drains on both sides are free so thinking it must be the AC.
Has anyone had this before and suggesting on how to check if it is the ac drain pipe?
I have replaced the AC filter
Kyemin
Portugal
Easy solution.
Buy this:
Works wonderfully. Follow the instructions on point and you'll never have that problem again. Trust me.
Remember to tell us all how it went and the difference. ;)
I have had a similar issue on a neighbours car found its usually the Air con smell like bad eggs
