arb bushes etc
jim.2007
billingham
im getting knocking from front so jacked its up, the bushes (all) are really gone, has anyone done replacements? any info on hassle etc and are poly bushes good or will it too hard a ride?
77minty77
Dublin
Ive only replaced my wishbone bushes for purple powerflex, not much stiffer over standard but sharpens front of the car up, good upgrade if bushings are gone anyway.
The Powerflex were designed for predominantly track & rally use so if your only using the car for domestic stick to the originals as the poly bushes have a habit hardening up over time plus start squeaking after a long period & are prone to cracking but its your choice
jim.2007
billingham
thanks for replies, off next month for two weeks will put on bushes along with 40mm spacers on wheels, 15mm just not wide enough!, dent booked in for august, will take before ad after pics of everything !
DanZad
Malta
Replaced all bushings front, rear and sway bar with Powerflex black-series; more steering response, more vibrations, car feels planted through corners (but depends on suspension setup). Overall firmer ride, losing comfort, but recommend for a sportier driving experience.
