Adjustable camber and castor?
GTlove
Hey guys
I was just wondering if anyone knows if the caster and camber is adjustable on the RCZ GT 156 petrol model.
I had 4 wheel alignment done recently after I changed the track roads and the drop links and the toe front and back were spot on. Iv had it tracked before and this was never the case. But the caster and camber still in the red. The mechanic said they're non adjustable.
Any Ideas ?
666
Fart land
Only toe is adjustable on all cars, doesnt matter which make, for RCZ I didnt find any top shock plate, for adjusting camber and toe, looks like no one is making them, what are your caster and camber numbers
GTlove
ill show you. the strange thing is before I got the wheel alignment done everything was fine. Actually the camber was in the green on all axles the toe wasn't.When they changed it, the car started pulling. Now after a few alignment attempts the camber is out. Iv attached the Alignment before and after the first attempt and the last.
This one is when I got the car after they aligned it the first time
GTlove
this is the latest alignment
DanZad
Malta
Old post, new news re-camber adjustment; there are camber adjusting bolts however are not compatible with stock shocks. I bought powerflex camber bolts which fitted into bilstein b6 shocks.
