Billy Bob
Any ideas on this problem,
The code reader lists a fault with o/s abs sensor, upon inspection I found multiple problems
Broken coil spring
Bad discs front and rear
Rear pads sticking
Anti roll bar link
Strut mounts.
All of the above has been attended to but the ABS ESP lights are still on. I can clear the codes and drive the car but after a mile or so a beep beep and the lights reappear. My thoughts are now the abs module. The MOT is due on the 18th of April so I need to sort it out ASAP, can anyone shed any light on the problem. Thank you
Broken coil spring
Rear pads sticking
Anti roll bar link
Strut mounts.
