AwesomeRob
Hi,
I recently purchased an RCZ Asphalt.
I can only assume that who did the service at the dealer before I bought the car didn't tighten up the Turbo Pipe and screw in sump plug tight enough because it empties oil all over the drive. I had a new sump, oil and tighten of the turbo pipe. There's a post on here with details about that.
A day later got an EM light, lumpy idle, no acceleration so decided to buy a good diagnostic device.
It came back with these codes:
P1336 - State: Intermittent - Misfire on Undetermined Cylinders
P1338 - State: Intermittent - Misfire On Cylinder 2
P0012 - State: Permanent - Inlet Camshaft Dephasing Coherence
P2263 - State: Intermittent - TurbOpen Circuitharging Pressure Regulation Fault Measured Pressure Too High
I've done some research and it could literally be anything:
HPFP
Coil Pack
Oil Sensor
Timing Chain
EGR
etc
From those that know a lot about these cars what do people thing the most likely cause is?
I can also get live data graphs if needed.
HPFP
Coil Pack
Oil Sensor
Timing Chain
EGR
etc
